Old 08-06-2007, 05:45 PM   #1
Dick Butler
Liked 32 Times in 19 Posts
Wink Re: Please Help Me Get This Thing To Hook Again!
Did you use same tires? Did you "tune up" the motor in any way?
Old 08-06-2007, 08:15 PM   #2
Arnold Greene
Liked 3 Times in 2 Posts
Default Re: Please Help Me Get This Thing To Hook Again!
Eric, if your rear spring eye o.d. is against the frame rail, it will not allow the spring to work. Either your car is sitting too low, the springs are too long, or your shackles are too short. Are the shackles leaning forward or to the rear? Are they stock or aftermarket? Also, the slide-a-link works better with near '0' pinion angle. Three degrees would work if you had slapper bars. Hope this helps.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
Old 08-07-2007, 08:58 AM   #3
ericsz
The shackles were stock they were also leaning toward the back of the car, I put some adjustable shackles on it now I have at least 2 inches from the spring eye to the frame, I also put a set of 10 inch wheels with 28x10.5 stiffs on it hopefully this will fix it.
ericsz is offline   Reply With Quote
Old 08-07-2007, 09:19 AM   #4
rx dealer
Liked 53 Times in 13 Posts
how old are your slicks??? 2 years or older?? 40-60 runs?? many weekend racers run the slicks until they are worn to nothing,,,do you rotate your slicks after every run ??? what is your 60 foot times??...good luck...luke
rx dealer is offline   Reply With Quote
Old 08-07-2007, 11:27 AM   #5
ericsz
read first post closely! Mickey Thompson supplies me with tires, currently tires are 2 weeks old with probably 30 passes on them, didnt matter when they were brand new still didnt hook!
Old 08-07-2007, 09:20 PM   #6
40Coupe
You want to fix the problem. AFCO p/n: 1870 DA's for the rear.
40Coupe is offline   Reply With Quote
