Old 02-16-2013, 01:44 AM   #1
69camz28
Default Battery Box?
Hey guys.....I have a 69 Camaro that will run high 9s. Battery has been moved to the trunk and it has a fuel cell in the trunk also. I plan on running it in NHRA Super Gas a couple times.... Does it need a battery box? Any help is appreciated.
Jeff
69camz28 is offline   Reply With Quote
Old 02-16-2013, 12:56 PM   #2
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Default Re: Battery Box?
You need to seal the drivers area off from the trunk with either sheet metal or aluminum. Not sure of the thickness though. I believe it's .032 aluminum or .026 steel. Check in the rulebook to be sure. Hope this helps.
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
Old 02-16-2013, 08:18 PM   #3
Kegracing
No battery box required, last I looked. Must have 3/8" or larger hold down rods or all thread with metal cross bar,for the battery. Also, if you have a traditional battery, make sure you have it running across the trunk, so plates do not snap and ground internal, on launch. Do not run in direction of car...using gel or glass mat battery will also solve this, as they can face any direction with no problem.
As stated, trunk must be sealed with metal to close all opening,for both the fuel cell and battery.
Good luck.
Ken
Kegracing is offline   Reply With Quote
Old 02-16-2013, 09:50 PM   #4
69camz28
Thank you!
Old 02-16-2013, 11:31 PM   #5
Stewart Way
Liked 70 Times in 22 Posts
The 2 3/8" hold down bolts or rods cant just go thru the trunk floor and have a large washer under them. They must be attached to the frame or an extension from the frame so if an impact occurs the bolts just don't tear the sheet metal.
Stewart Way 2424 SS
