Old 02-14-2013, 08:03 AM   #1
jims5600
Liked 21 Times in 9 Posts
Default Re: 79 Malibu stock suspension build
Very nice work Todd
jims5600 is offline   Reply With Quote
Old 02-14-2013, 09:47 AM   #2
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 17 Times in 7 Posts
If you did the work yourself......be very proud! It's a very nicely done car!
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 02-14-2013, 09:58 AM   #3
Todd Geisler
Liked 345 Times in 149 Posts
Thanks guys. I did all the fabrication, welding, sheetmetal work, wiring, plumbing and assembly. The only things I didn't do are the chassis/cage powder coating, body/paint and the custom carpet.
Danny, the intake was a Brodix 2017 that matches the head Hunter MC heads. The carb used to be a Pro Systems 1300XE when it was run on C-15, now have an APD 1250 calibrated for Q16.
Right now the engine is at BES where Tony Bischoff and his crew are making some HP upgrades along with freshening. Should be back in a couple more weeks. In the past I have assembled all my own engines, but this time around we did some custom stuff to where I felt it wise to have Tony do the final mockup and assembly.
Todd Geisler is offline   Reply With Quote
Old 02-14-2013, 11:19 PM   #4
Todd Geisler
Couple quick videos.
This one is prior to the rebuild.
In car Go Pro video first race after the rebuild. Slug out of the hole with a ton of power taken out.
Test session after having the converter tweaked. Getting after it much better, but still prior to the Q16 carb/fuel swap.
Old 02-15-2013, 10:12 AM   #5
nickh
nickh's Avatar
Liked 648 Times in 193 Posts
Todd beautiful work
How many passes out of those 275's before you have to put new ones on? Are you rotating tires left to right?
nickh is online now   Reply With Quote
Old 02-15-2013, 01:22 PM   #6
Todd Geisler
Originally Posted by nickh View Post
Todd beautiful work
Thank you.
This set of tires had 40 runs on them when last season ended. I might use them for the first testing of this season and put a fresh set on for the first race.
I do not swap sides as the tread slots make the tire directional.
Some of these small tire higher hp cars only get say 10-12 runs on a 10.5 x 28 stiff slick. I know some racers on the old Mickey D/R that get less than 15 runs. I'm running the new 3754X Pro tire. So far very impressed with not only performance & consistency, but tire life as well.
Old 02-15-2013, 08:28 PM   #7
nickh
nickh's Avatar
that is impressive, we ran some outlaw 10.5 down here and on the older technology tires we got 15 passes max out of them (side wall was gone).
Old 03-11-2013, 11:20 AM   #8
Broadbent Bros Racing
Liked 17 Times in 2 Posts
That is one clean looking Malibu. Very nice work.
Broadbent Bros Racing is offline   Reply With Quote
Old 02-15-2013, 11:57 PM   #9
Geerhead55
Liked 5 Times in 5 Posts
Thumbs up Re: 79 Malibu stock suspension build
Thanks for the info,, Todd. Thats a cool looking piece,, take care.
Danny Durham
Old 02-16-2013, 12:10 AM   #10
Todd Geisler
Danny Durham
Your welcome and thank you Danny.
