#11 |
And that's what I meant without getting into the action of the shock. The rear of the springs does "suspend" the rear of the car. The "suspension" as I called it is the act of controlling the movement of the rear of the car suspended by a leaf spring in this case.
Jeff Lee 7494 D/S '70 AMX |
#12 |
Liked 165 Times in 59 Posts
you really cant say that its compared to a ladder bar ,or even a slapper bar ,,, it works more like a canter lever ,,,as the power is applied to the drive shaft the rear begins to rotate, at that point the lever action is moved to the pivot bell crank of the cal track witch loads the front of the spring where flexing takes place the most ,, even cars with big horse power the body has minimal separation from the tire ,,,it gives the rear a chance to rotate and hit the tire with out the shock of a slapper bar,not as solid as a ladder bar ,,, great design in my opinion ,, I am used to making my own stuff but ,it works gmonde
#13 | |
Guest
Posts: n/a
#14 |
Trivia: Competition Engineering made the "slide-a-link" back in 1972 or so. A friend of mine has them on his '72 Demon 340 G/S (?) that hasn't changed since he built it from a new car in 1972. Based on that, I'm under the impression John Calvert borrowed the concept and improved on it by eliminating the soft spot in the middle of the bar.
Which begs the question; which version is better? Personally, I see no use for the urethane shock absorber in the middle of the bar. But I see there are some real fans of the design. It would be an interesting test on the same car. Anybody here try testing the two?
#15 | |
Semantics aside, I'd say they constitute one link, all inclusive. The "missing link" would have to be above the axle center line on the housing to function like a true 4 link.
#16 | |
That would be an interesting test. I do know of one racer who switched for the slide a link to the Cal tracs and saw a major improvement. I think the difference between the two is the slide a link will work with a steel multi leaf spring, where a Cal Trac works best with a mono leaf. From what I've seen, I'm yet to see a car with multi leaf srpings work like one with a mono leaf when using the Cal Trac set up. But I've seen some good working cars using Slide a links and multi leaf springs. George (still using SS springs) |
#17 |
Liked 2,343 Times in 465 Posts
Jeff the opposite is true. Cal Tracs came before slide o link. I had gone threw Moroso when they were designing the slide o link. Guess what was lying on the table. Are you sure your friend didn't have the Steve Hanby set up. Barry
#18 |
Liked 319 Times in 68 Posts
Autofab in Maryland had a setup like Cal - Tracs in the late 80's early 90's I had them on my E/SA 68 Camaro with fiberglass Mono - Leafs.
Lee Valentine 1661 STK |
#19 |
Liked 883 Times in 237 Posts
They all owe their basic design to the ET Traction Master bars.
I had these on my first car in '69 , and they were around long before that ! One of my Uncles' had a set on his C/A '47 Ford in the early '60's The newer bars have refined the adjustability and function, but the basic concept belongs to ET.
#20 | |
Liked 8 Times in 7 Posts
i'd heard of 'em but never seen one...how'd they work? plan is (on my rambler) to try cal-tracs, slappers and just clamping the springs...this gives me one more thing to try ![]()
without losers,winning means nothing. |
