If you think $425 is a lot of money for a nostalgic intake manifold that has a high "cool factor", you will be looking a long time!
I seriously doubt this will work on your low compression, low lift cam 350. It's designed for high RPM race engines from Trans-Am days.
Jeff Lee 7494 D/S '70 AMX |
Liked 54 Times in 27 Posts
I know a guy who tried it in the 1970s on a strong high rpm street-strip Chevelle. Based on the hype I thought it would work well, sort of like a cross ram. Turns out, the Tarantula walked all over it.
I think any box style intake needs extensive internal modifications to work on the strip, even more for the street. They are cool looking but it takes a lot to make them work. Direct Connection used to have a tech bulletin on modifying the Weind two piece intakes.
Edelbrock made the STR series and AMC guys love the cross-ram as they were factory on the SS/AMX's. Most cars run faster when they put a 750-850 Holley on a Torker. But go to a car show with a cross-ram and open the hood and everybody lines up and drools.
That is the kind of information that helps, and I thank you for it. Having someone tell me how cool my junk is as they are walking over to congratulate the winner is not my idea of a good weekend. This was strictly about finding a competitive advantage, if there isn't one to be had with the Smokey Ram I will just move on. The rules state that I can run any single 4v intake manifold "as manufactured", aluminum or iron. No prototype, tunnel ram, or sheet metal intakes. Seems simple enough, just need to pick out the one that works best.
![]() Again, Thanks for your thoughts. |
[QUOTE=Jeff Lee;367577]If you think $425 is a lot of money for a nostalgic intake manifold that has a high "cool factor", you will be looking a long time!
QUOTE] you got that right...I just sold a M/T Crossram intake, for $900, last weekend on Ebay. |
