Old 01-29-2013, 12:33 PM   #14
FSA1673
Liked 12 Times in 6 Posts
Default Re: exhaust cross over (heat riser) fill
Originally Posted by dartman View Post
Heat riser passage may be
blocked from intake manifold side of cylinder head. Blocking
passage down in valve pocket prohibited.
I use thick tin between my intake gasket and head as i was told by the tech guy that pouring in is prohibited
Correct, I was under the impression as long as it does not protrude into the valve pocket you are OK. Exhaust runner volume still needs to meet minimum spec. Not sure how you would measure it it if was not filled.
Adam good to hear it is worth power.
Scott
FSA1673 is offline   Reply With Quote
