Old 01-27-2013, 05:35 PM   #4
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: 2004 Jerico DR4 with 2.83 1st gear
[QUOTE= I should mention... This particular transmission uses GM 26 spline input, with the large GM M22 / TH 400 size output. The case and configuration replaces a regular GM Muncie M22 or B/W Super T10.[/QUOTE]
Any idea what would need to be changed to configure the trans to fit a 1965 Mustang? Are the tailhousing and output shaft length the same?
