#31 |
#32 |
#33 |
Liked 10 Times in 6 Posts
CW posted the latest news on Moparts.559,559M,559M-1 heads will be allowed to break thru at the intake flange surface,but the hole at the top(v/c gasket surface) must remain intact and in stock location.Heads already milled into the bolt hole need to be replaced. Check his post on Moparts to be sure I got it correct.
#34 |
Liked 3,199 Times in 977 Posts
Here's the link to the Moparts post Dana referenced....
http://board.moparts.org/ubbthreads/...0&fpart=2&vc=1
#35 |
Liked 679 Times in 180 Posts
"Except" Pg. 11
No wonder we are 40 down.......... |
#36 |
Liked 6 Times in 5 Posts
RB, CW, MCH or VED heads are not all illegal, only one brand as far as I know. Not all heads in the class are illegal. The heads cant be milled into the V/C bolt at the gasket surface, thats the line that you cant cross. Its been that way since before I started racing in 1991. This isnt a big deal to anyone other than the ones that do business with someone who cant read the rules. As I told you on the phone when you called, either 6 or so people have to buy new heads, or the whole class will have to buy new one to compete with the cheaters. If they didnt enforce this rule, I would have showed you how to get creative when I milled the head till I got to the valve guide, and put a 2 inch spacer on it. I mean if you can get into the bolt, then where do you stop?
I wish everyone luck next weekend at gainsville. Now that the record is a minimum, someone new will be in teardown as we will not be there. That brings up another point I made, my dad an I are the only cars that have been torn down at a hemi shootout for the last 3 years so this stuff has been under a towel for who knows how long. happy Thanksgiving from the MILITIA cw cant wait to see you show up with a fe hemi charlie!!!! |
#37 |
It's a sad day at Black Hawk Hemiland. I
![]() Well, I am normally happy-go-lucky but since I ![]() ONE & DONE This class is in trouble. On to the Super Cars. I bet R&M can make a new COPO "STAND ON ONE TIRE AND BARK LIKE A DOG". |
#38 |
Liked 2,740 Times in 967 Posts
The N.H.R.A. has a habit of screwing stuff up, don't they.
#39 |
Liked 216 Times in 7 Posts
Its in the works. look out now. cw |
