Old 12-31-2012, 01:31 PM   #1
njk53
Default Spark Plug Indexing
My brother and I had a conversation the other day about the horsepower and performance gains from indexing your spark plugs. If you read articles on the internet you will hear of a different ranges of gains.
My brother said he read an article by Smokey Yunick who said he tried different variations of spark plug indexing and yielded absolutely nothing and wasn't worth the effort.
Does anyone know of anyone who has test data to prove if indexing is worth it?
Nelson Kowal
Stock 345
Old 12-31-2012, 01:34 PM   #2
art leong
Default Re: Spark Plug Indexing
From what I have gathered. Indexing is more for clearance than anything else.
Art Leong 2095 SS
Old 12-31-2012, 02:05 PM   #3
richie 2
Liked 205 Times in 93 Posts
promotes an efficient flame travel resulting in a more complete burn of the air/fuel mixture.
Old 12-31-2012, 02:27 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Considering the myriad of combustion chamber designs coupled with an almost infinite variety of piston tops and adding in the countless bore-stroke-compression ratio-valve size combination and then the many ignition systems and spark plug designs, there is no hard a fast rule. If you want to know if it works, try it. Keep good records.
Old 01-03-2013, 01:13 AM   #5
Steve Williams
Nelson,
I assume you have a Chevrolet small block. What I found out concerning indexing and plugs is real simple. There is a small difference in power when used with timing change. The plug can be modified and combined with indexing a little more can be had. I tried different types of plugs. ground strap designs and gaps. Some of the plugs that people are/were paying big money for were absolute junk. One particular plug actually made less power by almost 10hp and it was the rage for about two years. Until word got out about how cheap they were. I modify my plugs ground strap and index all mine. I also use plugs that are not as expensive as many out there, but have good quality. As far as printed test data, I am sure it is out there in some publication. Indexing for clearance is something that many aluminum rod engines should do to avoid possibly nicking a plug.
Steve Williams is offline   Reply With Quote
Old 01-03-2013, 07:13 PM   #6
SGSST109E
Liked 126 Times in 61 Posts
The biggest gain is the removal of the risk of closing a plug gap and losing all the HP in that cylinder.
SGSST109E is offline   Reply With Quote
Old 01-08-2013, 02:02 PM   #7
njk53
Our car is a big block (402 CI) Chevrolet. From the comments I gather that with the forward or open part of the spark plug facing the intake valve, this position will promote more efficient combustion which yields an increase in energy, translating to more power/performance correct?
Would an engine with a lower compression ratio yield better performance than one with a higher CR? Or doesn't it matter?
I have a kit that I'm going to use to index our plugs. I'll keep records and let you know what we come up with.
Nelson Kowal
Stock 345
