Old 11-18-2012, 04:09 PM   #9
treessavoy
Liked 4 Times in 4 Posts
Default Re: Aftermarket Cranks
Originally Posted by CaptCobrajet View Post
That would be a great way to turn some more racers away from NHRA. When Stockers inherited the Super Stock rod list...............way before spacer bearings were an issue in Super Stock, some combos (not just the FE by the way) were blessed with rods that had been on the SS list for a long time. FE Stockers went to the barn at INDY with the pans off a long time ago, and were legal with the rod you bitch about. It would be the wrong thing for NHRA to do at this point, to take away parts from ANY make or combo, that racers have already spent their money on, that are (were) legal when they bought them.
NHRA tech knows that the intent of that language you quote on the undersizes was put there to keep SPACER BEARINGS out of Stockers............so a guy with a 440 Chrysler like yourself couldn't put a Honda bearing in a spacer, in a Stocker. The FE is not the only engine that has a rod approved with other than a stock journal......it just happens to be the engine that runs your class. If, for whatever reason, a connecting rod showed up on the list for a 440 with even a 2" crankpin, I'd wager that not one Ford racer would belly ache and whine about it.
I guess no one runs a 400 block in a 440 combo in Stock either, right? No journal issue there is there Larry?
The newer cars have such an advantage over the old ones that it is really a non-issue. Those rods were approved at a time when availability of parts (cranks and rods) was not what it is today. Removing approved parts from any combo of any make will only reduce car count and make it a show for the brand new cars, in the end.
For class racing to survive, there has to be some admendments here and there. The vast majority of Stockers are still OLD CARS. There are going to be changes that affect all combos either positively or negatively, from time to time. The changes, while upsetting to the purist, must come here and there to keep class racing alive. The challenge for NHRA is to try to make rule amendments, like the crankshafts this time, that help the racers keep racing. If some Hudson Hornet gets a part that it did not have, or a spec it did not have, the Factoring System will fix it way before it fixes the factors on the newer combos. Any part that helps any combo in terms of reliability and or availability should not be a sore spot at this point, for anyone who realizes that most of us are working with 30-40, even 50 year old stuff, and alot of it is not made anymore. The only answer is for NHRA to try to make changes that are rational and reasonable. I think that is harder to do than it looks.
BTW, Ohio crank doesn't MAKE a $500 FE crank. Cheap cranks are imported from China. I would not put a cheap Chinese iron crankshaft in my wheelchair. I would rather buy a good American set of Crower rods, and use a Ford crank, so NHRA won't have to pick up a bunch of Chinese iron off the racetrack when it flies apart and kills a block that is not made anymore. Most who take advantage of the new crank rule will not be buying junk..........that is the whole point of the amendment.........so racers don't have to use junk that they can't find anyway.
OK, you are obviously total ignorant about Mopar big blocks. First, the 400 and 440 are completely different physical sizes easily seen by just looking at them; second, there's a big raised pad on the front of a 440 that says: 440, the 400 has a machined pad on the left side of the block that says: 400, both have the block size cast on the side of the block. Different blocks, different sizes and clearly identified. Who would want to give up 40 inches?
JimR
Jim Rountree
