Guest
Posts: n/a
It's the rod that is approved to use that size journal , has nothing to do with the cranks.
Liked 10 Times in 6 Posts
Mike, were is the list of approved crankshafts? Tom
Tom Moock 5704 STK |
Liked 2 Times in 2 Posts
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 1,583 Times in 582 Posts
Here we go again!!!
Hold on and let me grab the Popcorn!!! ![]() |
Liked 231 Times in 107 Posts
Don't cha just lov em? |
Larry,
I think the time has come for you to build a CJ. With the new aluminum police interceptor intake that's legal, the big 780 quick fuel carb, high port edelbrock heads and the 525 cheater cam, this thing should be able to run 9.50's in B/SA. The chevy rods are a bonus too and you should be able to spin it up to 8500. The aftermarket crank rule helps. I'm trying to the the honda rod approved for the FE and working with Wineberg on a new 41 lb crank. Should work well. Rusty |
#7 | |
Liked 780 Times in 194 Posts
Liked 10,720 Times in 2,232 Posts
Todd if the cranks can only be turned to -.070 under OEM size, the "length custom" rod with housing bore of 2.325'' would have to be installed with a four pound hammer. It would be my quess that unless great care was taken during assembly the assembler would would collaps the top and second ring land before the bolts and cap would be close enough to be tightened. Once tightened the broaching process of the crankshaft will be compleated.
Rusty the .525/.525 cam is the 427 one or two four barrel you know 410 and 425 hp. The "cheater cam", your words not mine, is .527/.527, it can check .525/ .525. After some thought I believe the engine stand or the snout of the crank would break before all eight piston and rods were in place and torqued. |
Larry, "Cheater Cam" was probably a poor choice of words. I like "enhanced cam specs" better. I think the 427 guys need to get the pencil and paper out and go after that extra 2 thou. That would certainly level the playing field with the Drag Packs, Copos and new CJs.
Rusty |
