Old 10-02-2012, 10:53 AM   #1
sportsfan
Default X- pipe exhaust
I am considering installing an X-pipe exhaust system(without mufflers) on a Chevelle with a SBC.Now I am using headers with bullet mufflers.I have read that I will pickup HP,but will there be any performance gains after adding the extra weight of the new exhaust system?
sportsfan is offline   Reply With Quote
Old 10-02-2012, 11:01 AM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: X- pipe exhaust
We picked up .3 in the eighth with a flat top, 336 69 nova, with cast manifolds. The weight did not hurt it. Would expect something even with headers. Someone else may have more input.
don,t have one
Old 10-05-2012, 04:36 AM   #3
Footbrake
Footbrake's Avatar
My car runs .1-.15 faster in the 1/8 with 3" x pipe and mufflers with turndowns, than with open headers. There's something to that technology I guess
Footbrake is offline   Reply With Quote
Old 10-05-2012, 11:40 AM   #4
Jeff Stout
Liked 706 Times in 283 Posts
Had bullets about mid car. Went to full exhuast out the back with x-pipe in proper location. Gained 45 lbs weight and picked up .04 et. sbc
Old 10-05-2012, 02:14 PM   #5
Ed Wright
Ed Wright's Avatar
Jeff, how can you be sure about four hundredths, week-to-week. Surely you didn't back-to-back that system at the track, same day?
Ed Wright 4156 SS/JA
Old 10-05-2012, 09:40 PM   #6
7423
I have 3" collectors into a 3" X pipe and into a pair of dual chamber Flowmaster mufflers with turn downs. X pipe and mufflers weigh 44lbs.
Remove the system and run open headers with a collector extension, add 40lbs of lead and the car runs .10 slower et and 1.5 mph slower.
That was a back to back test, within 45 minutes. I have done this several times.
X pipe and mufflers, would not leave home without them.
7423 is offline   Reply With Quote
Old 10-05-2012, 10:43 PM   #7
sportsfan
OK, I'm sold on the benefits of the X pipe.Should I use my bullet mufflers or just turn downs? Or test both combos?
