Old 09-18-2012, 01:57 PM   #10
SST159
Liked 20 Times in 16 Posts
Default Re: Hood Scoop issues
yes, I did tie the vents together and it still pops. I am currently fabricating a full pan to totally seal off the scoop tight along with sealing off the open back of the scoop at the windsheild. hopefully I can get out to test next week. If that does not correct it then next step would be to try a filter. Problem is there are too many filter options to select from. What I cannot figure out is I see many racers run these hood scoops with no pan and wide open in the back and have no problems. Perhaps the air turbulance does not affect a dominator as it does the 4150. I think my car is pissed off at me for something. Bad enough when the wife gets pissed but when the race car does??? Thanks for the suggestions and still welcome any more if available.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
