#61 | |
Dave, it does seem to be a bigger problem down here with the high heat and humidity.
Chad Rhodes 2113 I/SA |
#62 |
Sponsor
Liked 1,045 Times in 70 Posts
I would vote for random checks during qualifying and only for heads up runs in eliminations, but as someone said earlier, sometimes its not done on a heads up run. EVERY TIME there is a heads up run in eliminations there needs to be scales and fuel check. I remember winning a late round heads up one time in Atlanta years ago, and I had gotten out to actually push the car to the scales, 'cause I knew I'd be dead on and didn't want to burn a drop of gas. When they started motioning me by, I didn't agrue, I just hauled ***, lol.
#63 |
Liked 534 Times in 143 Posts
You probably sweated out the difference.
#64 | |
Liked 282 Times in 103 Posts
Its not really a "BINGO" since we race two cars and use the same fuel. Fuel check has never been a problem at a Division race,but I have been to a couple of additional National events (Bristol and Brainerd) and ironically,those were the places where the fuel was "borderline".EVERYWHERE else,NO problem...either car. (same fuel) How can you explain going to a Division race with good fuel,going to a National event with "borderline" fuel,and then to a Division race with good fuel all in a few weeks time? Would you say "BINGO",this fuel is no good? |
#65 |
I have been away from class racing for quite a few years so I`ll start from the beginning of my recent experience ,right before the "Dutch Classic" last year I was given the opportunity to borrow a car for the race,the car had sat under a cover outside for about 1 year it had approx. 1/2 tank of C12 in it.
The car needed some minor work and and we did not have a lot of time to get it ready, Dennis Chapman (The cars Owner) Thought we should drain the fuel and add fresh to be sure it would pass fuel check,to make a long story short I did not drain it but brought some empty jugs along just in case,I also purchased 5 gal.s of fresh C12, Prior to the 1st. Qualifying pass I ran the car over the scales and had the old and new fuel checked,both passed! One thing that Dennis told me to do was a soon as your done drawing the sample from the car was to cover the container with the palm of your other hand as you walk it over to the table,I have not seen this mentioned and I don`t know if it matters but I have not had a problem with fuel check.(Checked 8 times this year) Fast forward to last weekend at Englishtown we set the C/FS record, as many of you know when you set the record you are given a tech card with the car weight and fuel test #s and the engine is sealed,then on the back up run the weight and fuel numbers are are recorded again,here`s the thing that struck me funny, the same fuel was in the car, we did not add a drop after the 1 st. run but the fuel check numbers on the card were different ! It passed both times but I wonder why there was a difference a few hours latter? Maybe temperature has something to do with it? With fuel cost being what it is I do think that if fuel checks lower then it should you should be allowed to run it. Just my opinion! ![]() |
#66 | |
Renegade Racing Fuels were just added to the accepted fuels lists this season and every grade submitted was very carefully tested by NHRA to be sure the spec sample was representative. |
#67 |
Liked 43 Times in 15 Posts
After reading many of the post on this topic the conclusion is obvious.The gas companys are providing us with fuel that has a shelf life of somewere between a year and a day.Well maybe its my fault i didnt hold my hand over my cup during fuel check.Or worst then that I let the sunlight hit it or I forgot to make the sign of the cross when im fuel the car up,that must be it.We are paying a premium for a product and when that product doesnt do what its suppose to do YOU did something wrong.
Joe Mocci 1424 m/sa |
#68 | |
Liked 175 Times in 78 Posts
They do not know what they are testing for and the TEST IS FLAWED - it is not the few guys who know what they are doing and occasionaly - seemingly randomly are accused of cheating without using the word - I say throw them out of the race and then more of you guys would get it and tell NHRA to FIX THE TEST - the reason they don't kick you out is they know the TEST IS FLAWED I suppose if they told you - if you roll up one pant leg above the knee when you walk your fuel over you will pass - 85% you guys would do it and believe it - LMAO THE TEST IS FLAWED Ron BTW - a higher number does not mean more power just like a low number does not mean less power - Geez you guys get a grip - learn what they are testing for specifically and how the test actually works
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham Last edited by Andys dad; 09-18-2012 at 09:46 PM. |
#69 | |
Liked 10 Times in 1 Post
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
#70 |
