Liked 163 Times in 53 Posts
Let's see who really really lets it all hang out and takes all the weight out of there cars...
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Are they running class at this event? Record runs?
no class RO's. Nat opens are where the RACERS set records! this has been an on goin thing for a while about setting records or running fast as you can in class and not getting hit with HP....
There will be alot of them taking the block of wood from behind the pedal this go around..
Liked 10 Times in 6 Posts
Stephen, at National opens if go more than 1.20 under you get Hp. but runs don`t count on your average`s. Tom
Tom Moock 5704 STK |
tom , the reason why i made this post is because i got an email that the AFHS is not goin to count for this race..it was voted not to count against ya!!!!!!!!
Stephen, sounds like a combo race not a NHRA Open with record runs.Tom
It is a national open with record runs. I believe there will be no normal AHFS but if you go more than 1.199 under you will get the instant hit. Whether you set a record or not.
Art Leong 2095 SS |
Liked 58 Times in 18 Posts
No vote nessary, that is the way all national opens are run, no HP unless you go 1.20 under then you get the instant hit on monday or tuesday the next week! some combo's still need that block of wood under the pedal
Those of us that got the email from Mike Crutchfield........ It says NO AHFS, none zip, nada, take the lead out and and bomb the record 1.20 under be damned.
Chad Rhodes 2113 I/SA |
Liked 444 Times in 145 Posts
They may be saying the ahfs is not in play, but I would be very surprised if they will let a -1.20 run slide.
Bruce Noland 1788 STK |
