Old 07-07-2007, 09:46 PM   #3
Mike Hedger
Default Re: Hard tail dragster problem
I started with the same pressure I had in the old tires and when it did it the first time I was at a Nat event going into the last TT so I asked Farren from Hoosier for advice and went with it. I have not tried to go up on pressure yet I am going to try another converter a buddy has (the one I put in to try was my spare and after loaning it out it came back broken) So the trans has to come out anyway. I will try the tire pressure up a little at a time to see if it makes any diff. Yhank you, Mike
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
