09-07-2012, 05:05 PM
#1
Liked 174 Times in 39 Posts
Re: The damage recently done
Originally Posted by Jeff Lee
I've not been ignoring this. Just working.
As pointed out, there is a book full of allowable items in S/SS that some find objectionable. Some, but not nearly all, of it already pointed out on this thread. When I last raced in D/S, I raced against some pretty good running 390 Mustangs and the Boss 351 of Rob Youngblood. The Boss 351 had a 780 Holley in lieu of the factory 4300D. The 390 Mustang had a 735 Holley instead of the 600 Holley on top of a Police Interceptor aluminum hi-rise instead of the flat cast iron unit. And it got a 8 qt oil pan. But who cares, it's in the books and the books allow everybody access so you can build any car you want with parts that suit your needs.
No need to go look at the '60's Shelby offerings that have popped up lately, it's been discussed to death here. Same with 383 two four barrels, hi-compression Pontiac's, 327 intakes on 283's, Oldsmobile cams, you name it, it's out there.
And Billy, I don't know if you race IHRA but I do think it's in your area of the country so I'm assuming you do. But had you been looking, you might have found IHRA accepted the Holley for Stock on AMC about 9 years ago.
NHRA just now put it in the books. And AMC themselves submitted the larger cam to NHRA DECADES ago. I brought it up and they found it in their archives.
And Blue Oval, you're right. It was in the AMA specifications. A bunch of you critics are probably to young to know what that's all about. The OEM submitted specifications to the AMA about everything (wheel cylinder volume, spring weight for ignition points, trunk volume, etc., etc., etc.).NHRA used AMA specifications as a source guide.
I have been dealing with NHRA on this for 12 years. I've been told everything I submitted was what they wanted to see and then told "no" for no explainable reason. I've been told to get this or that and "were good to go" then told no. I never threatened to use an attorney and wouldn't know any of the NHRA tech officials if they showed up at my door this afternoon. I just never gave up because I had the documentation and I knew it was right.
And for "Super Trick", I raced D/S last about 7 years ago. My ET's were 10.55-10.65 here in Arizona; never made it to a sea level track. And that was with a .457" cam, cast iron intake and 4300 Autolite. I'd suggest if you have a comparable D/S or D/SA car, you should be able to do better with 7 years in advancements. But I doubt it.
For the record, I've posted on this site more than once LT-1 '70 Nova's should be allowed in S/SS. I've also stated I would love to see factory approved parts allowed by all makes. I'd personally love to see (maybe a separate class called "Trans Am Stock") with Cross-Ram '69 Z-28's vs. Cross-Boss Boss 302 Mustangs and Cross-Ram Javelins along with whatever "off road" cam that was available at the time. Stage II Buick's? Heck yea.
Anybody else...build an AMC. I'd love to have some competition. And in the end, I'm sure I'll be quite familiar with the AHFS.
So who do I need to talk to at NHRA about getting some "enhancements" for my D/SA car?
Btw, which AMCs were the bigger cam, aluminum manifold, and 780 holley installed on from the factory, I never got an answer to that question.
3207 D/SA, C/ED
