Old 09-07-2012, 06:30 AM   #1
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Default ? for you chevy folks
Is this article, below, correct. In 1973 did Chevrolet make a 427 with the 348/409 heads? Thought they built a 427, for NASCAR in 73, with late model straight head design or is this incorrect. Which one is right/ Thanks Frank
http://www.mecum.com/auctions/lot_de...=DA0912-140138
FrankChastain is offline   Reply With Quote
Old 09-07-2012, 07:21 AM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: ? for you chevy folks
63 not 73
and yes, they did...50, i think but i could be wrong...probably a few more engines than cars, though..
http://www.348-409.com/z11.html
Old 09-07-2012, 07:33 AM   #3
Billy Nees
I'm not a 409 expert but I'm pretty sure you're right Frank. The NASCAR motors had Big Block type heads on them. The Z-11s were 409s.
Billy Nees 1188 STK, SS
Old 09-07-2012, 03:22 PM   #4
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Smile Re: ? for you chevy folks
The NASCAR 427 was an early "BIG BLOCK" called the "mistery motor" like we see today running in Camaros and such. The Z-11 was a 409 type engine with a stroker crank making it a 427 inch engine. The heads were of the "W" type like a 409 but the intake ports resembled current square ports on the 427/396 Hi performance engines though not quite as large. The 348/and early 61-62 engines had smaller intake ports and valves. The 63 LoPo 409/340 HP had 348 type heads with small intake ports and valves. The intake on the Z-11 was a 2 piece deal with a valley cover with standard 409/425 HP AFB carbs and the engine had 13.5 compression. Most all else in the engine was like a 409/425 HP with a slightly bigger cam and stronger valve springs. The cars were built in 2 different runs of 25. They were ALL bench seat 2 door Impalas only. The first 25 did NOT have and engine insignia on the front fenders as Chevrolete did not cast any with a 427 script. Dave Strickler and "Da Grump had the # 1 car delivered right before Christmas of 1962 at Ammon R. Smith in York Pa.. The "last" 25 Impalas had a set of 327 numbers with crossed flags on the front fenders like a 327 250 HP or 300 HP car. When the racing ban came down from GM officals they had enough parts to finish building 7 more cars. Total 57 cars although some will argue other wise. All 57 were 4-speed sticks with BW T-10s and bigger brakes with air intakes and a stronger third member. The front bumper and rear bumper was made of alum. The hood, fenders, core support were also very thin alum of about 26 gauge. The inner fender pannels were OEM steel although Grump installed alum. inner fender pannels from their 1962 Belaire hardtop. The Z-11's also had a nascar type air cleaner attached at the firewall similar like the 67/68 Camaro Z-28's. Non were ever Byscaynes or Belaires. I have some funny stories I got from Dyno Don Nicholson before he passed away about trying to keep one running every weekend with 10 inch tires. Hope this helps.
Old 09-07-2012, 04:26 PM   #5
FrankChastain
Originally Posted by Tom keedle View Post
63 not 73
Thanks, must have had 73 on my mind......
Old 09-07-2012, 04:31 PM   #6
FrankChastain
Thanks to all you guys for making me wrong but, I learn something everyday and I enjoy it...X good to hear from you by the way...and thanks for the info....Frank
