Old 09-04-2012, 01:10 AM   #3
Bill Baer
Default Re: Trans brake issues
Originally Posted by C and W Racing View Post
Have you checked the ground? You say you checked the voltage, did you check it at a time it wasn't working properly? Is the wiring sufficient for the amperage it may need?
Chuck
I'm with Chuck on this one, I ground my solenoid to the battery, so I would check the ground or try running a jumper wire to ground the solenoid.
