Old 08-27-2012, 07:13 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Onan info
Well today I removed a CMM 7000 EFI unit for random shutdowns.
Bench tested it under load untill it failed...
Showed a Code 47 fault. Did it more than once.
I checked the coil connections to the controller and all was fine as it always is...
Installed a NEW 300-5047 Controller and continued to test the unit...
Ran the rest of the day on and off with various loads applied and no more shutdowns...
So for the umpteenth time a controller is at fault and the fault code it showed was somewhat misleading.....
And during the time I worked on this unit another customer came in with a similar problem......He may or may not be getting a controller also but he opted for a wait and see deal as we cleaned some wire connections....
My money is on him returning before the week is out to get the controller replaced.....and regretting not doing it today.......
Rich Biebel
S/C 1479
Stock 147R
Old 09-02-2012, 10:40 AM   #2
erkme73
Ok, here's my latest update.
Backstory:
My 7000 Marquis (gas) has been shutting down randomly WITHOUT generating any error code. As documented in my posts above, the unit would shut down abruptly as though someone had pressed the stop button. The reported error code was always an old code from a previous abnormal shutdown (i.e. low oil, fuel delivery).
Discovery since last post:
I removed the control module to inspect it carefully. The open side is filled with a clear epoxy/silicone material designed to encapsulate the circuit board and keep it dry. There were several pronounced cracks in this silicone in the corners. The cracks were deep enough to reach the PCB - and in one corner, the board and silicone were rusty colored (picture attached).
Actions:
Figuring moisture ingress was the likely cause of the intermittent shutdowns, I carefully and methodically stripped the silicone off of the board using a small flat-headed screwdriver. The glue came up surprisingly easily. I was unable to remove the PCB from the housing since the glue between the board and the housing was inaccessible. I then put the the module in my toaster oven at 175 deg F (no, I'm not kidding). I let it bake for an hour. As soon as it came out, I filled it with clear GE silicone II caulk from Home Depot for about $6 (picture attached). I let it sit overnight. The following morning, I reinstalled the control module in the genny, and let her run.
Results:
It's now been running for most of the morning without a single shutdown. While this doesn't mean anything (the random shutdowns sometimes went many hours between events), I'll let it run all day (and into the night if need be) to confirm that the shut downs are eliminated. I will post back my results once the testing is completed.
Given that my situation seems unique (shutdown without error code), I don't know how much my troubleshooting will help anyone. However, at a minimum, if you've performed all the possible diagnostics and are left with replacing the ECU, before you do, inspect the sealant carefully. Unless something is toasted on the board, you might just be able to revive it.
I figured I need a new board anyway - so I'm not going to break it more than it's already broken. Besides, I can learn more tricks this way
Name:	Onan ECU original.jpg
ID:	13445   Click image for larger version
Name:	Onan ECU resealed.jpg
erkme73 is offline   Reply With Quote
Old 09-02-2012, 04:13 PM   #3
Rich Biebel
The part number is 300-5047 for that A-1Controller as Onan calls it...
The boards fail regularly and there is NO visual area to see that is faulty.
They generally fail with heat and I let a unit run on my bench for a while with a resistive load bank connected to it....
Once it is good and warm.....I shut it down and let it sit for a while....It heat soaks so to speak. Any unit that has had intermittent shutdown problems will usually start to do it once I put them thru this test. As soon as the unit starts to shutdown......I replace the PC board/control and continue the same test and the units no longer shutdown...
I did 2 units this week.....
One got a new engine and a controller...
One got just a controller......
We called a company we deal with that does PC board testing and repairs....They do a lot of boards for us and also make some lower cost replacements for many common parts. They don't do this one.....
I have changed probably 15-20 of them in the last 5 years....
My prediction is you will be changing yours as well......
Rich Biebel
S/C 1479
Stock 147R
Old 09-02-2012, 04:18 PM   #4
erkme73
Rich, you may be right, but for $350, I'll take the chances that it was moisture getting to the 'rusty' part of the pcb. See the photo showing the large deep crack in the original sealant. After drying it out and resealing it, I've got 6 straight hours on it now, and it hasn't skipped a beat.
I just upgraded my 36' Damon gasser (the source for this generator) to a 42' Tiffin Phaeton diesel pusher. It has a 10k quiet diesel onan.
The only reason I want to get this genny fixed is so I can sell it to the next guy with a clean conscience. I'll let the buyer know that if the generator starts to shut down without error, they'll need to buy this controller.
Old 09-02-2012, 05:51 PM   #5
Rich Biebel
Those PC boards sell for $450 and I have seen them sold on various websites for over $500
I have seen the potting material split and cracked as you described.
Moisture is definately not a good thing for a PC board to be exposed to...
If you got it working with no shutdowns.....great.....
Rich Biebel
S/C 1479
Stock 147R
Old 09-03-2012, 12:48 AM   #6
Darrin Christen
Darrin Christen's Avatar
Where do you guys read these codes? I have a 7000 marquis, I think its a 1999 year model. I have had to replace the fuel pump several times in the last few years. After the original onan pump quit I replaced it with a $50 low pressure pump from the Advanced Auto part because we were at a race when it gave up. The $50 pumps look just like the onan pump, but they don't seem to last very long. Is the Onan pump really worth the $260 they cost?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 09-03-2012, 12:52 AM   #7
erkme73
It's the government-mandated ethenol that kills the pumps. I doubt an Onan pump would do any better.
To get the code, press the stop/prime button 3x within 5 seconds. It'll then blink a single digit. Press it one more time, and it'll blink a two-digit code.
A fuel pump problem will generate a generic 36 - which stands for fuel delivery problem. Could be a pump issue, low fuel level, leaking fuel line, gummed carb, or anything else that causes the genny to starve of fuel.
It's probably one of the more common codes.
