Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 06-26-2007, 05:12 PM   #1
M S Watchdog
Default 9 1/2 Ford
Lincoln made a 9 1/2" ring gear it would fit a ford housing with a notch for clearance on the mounting flange for the third member.
Not true it is 9 3/8 not the same, no nodular cases were ever made. the caps will break and the tail bearing retainer in the case will also crack. Every thing in the pig is just a little bigger the ring gear bolt circle is bigger. The 9 1/2 is different contack MW or Strange to see if if it will fit in your housing.
M S Watchdog is offline   Reply With Quote
