Will consider trades for 565 or larger BBC
-Bowtie 184 block w/all machine work done and rear main seal upgrade -Hogan's sheet metal intake -APD Dominator built for this motor -14* Pro-Action heads complete with springs and titanium valves -Jesel shaft rockers -Jesel belt drive -Crane Ultra Pro .904 lifters andComp Cams special grind cam -Eagle 3.875 crankshaft -Eagle 5.85 rods -JE custom 4.165 bore pistons -Complete Stef's dry sump system includes Barnes 5 stage dry sump pump -ATI Superdamper -MSD front mount distributor -MSD crank trigger setup -Moroso Unltra 40 Plug wire -SFI flexplate -CSI waterpump Asking $15,000 Call Scott 330-338-3916 |
