Liked 584 Times in 94 Posts
Per Tony James: if the chambers check CC, and the runners check CC.... ie : Stevie Wonder and Ray Charles ....it's legal
Liked 544 Times in 213 Posts
CYLINDER HEADS
Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA accepted. Porting, polishing, welding, epoxying and acid-porting prohibited. Combustion-chamber modifications prohibited. Cylinder heads are additionally restricted in that they must retain original-size valves at original angles +/- 1 degree and must be able to hold original cylinder-head volume per NHRA Specifications. Runner volumes may not exceed the current Super Stock cylinder-head volumes as listed on www.NHRARacer.com. Regardless of the poured volume measurement, any modifications to intake or exhaust runners prohibited. Any evidence of modifications from the original castings will be grounds for disqualifications as determined by NHRA in NHRA’s sole and absolute discretion. Any aftermarket steel valve permitted, must retain stock head and stem diameters. Only engines OEM-equipped with sodium-filled valves may use sodiumfilled replacement valves. Titanium prohibited. Hardened keepers permitted. Lash caps prohibited. Valve-diameter tolerance: +.005- inch or -.015-inch from NHRA Specs. The following are prohibited: spark-plug adapters; cylinder-head studs; any grinding in ports or combustion chambers; removal of any flashings; sandblasting or any other modification to cylinder head; any film coating of intake and exhaust runners; any film coating of combustion chamber. Runners and combustion chamber must retain OEM appearance. Final acceptance as determined by NHRA in NHRA’s sole and absolute discretion. Intake side of head may not be cut into any part of valve cover bolt holes. Heat riser passage may be blocked from intake manifold side of cylinder head. Blocking passage down in valve pocket prohibited. The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronzewall valve guides. Valve spring umbrellas optional. Cylinder head may have all of the seats replaced. Any valve job permitted,Oringing prohibited. Exhaust plates prohibited. Forgive my ignorance but nowhere in any rulebook today or ever has it said a Stock cylinder head was legal as long as it CC'ed right on the chamber and ports. This stuff is one of the reasons I don't run stock even though I have...... In the '60 s when I first started racing Stock.....just about any cylinder head that showed up on a table in a teardown barn with some of these modifcations mentioned would have been bounced in a NY minute.......
#3 | |
Guest
Posts: n/a
And they caught everything???? Nobody ever got away with any cylinder head work? The Monster Mash car that was as fast a A cars, that ran as fast as super stock cars back in the mid 60 was just tuned better than most? Jenkins was just, jetting and tuning a second better than anybody else? Its all bull sh*&. Guys maybe got away with less, but they still got away with stuff. I feel that the 60's and 70's were the best time to race our classes, but i don't believe it was without controversy, and guys bending the rules.
I thought the Jr Stock were out of controll with mods and thats why they reeled the class back in. All the 50's cars were kicked out and that was final. We are almost 40 years removed from that season. Is stock class all that bad now? Quote:
Maybe you need to check your facts Todd..
The Monster Mash was a 265 in a 55 Chevy with a 3 speed.....Lots of other cars just like it were also fast back than and if any of them had bogus heads like today and set a record they would have been thown the hell out......When we raced against the Monster Mash it was a 14 or 15 second car.... Did guys cheat and bend the rules and get away with it.....Well I am sure they did....but most didn't for fear of being caught. I raced 2 cars from 1966 to 1970. Both were legal and ran pretty close to what most other cars of the day ran or faster. I never said anything was wrong with Stock...... People like myself are just pointing out the way the rulebook is written about heads.... Ask Walter what he thinks....
#5 | |
Liked 7,781 Times in 1,743 Posts
Today you're as likely to hit the lottery as to be torn down unless you plan on going to Indy and then your chances are what, 5 %?
Liked 5 Times in 4 Posts
" Any valve job permitted " What does that really mean? In old rule books NHRA gave you an example of what an accepted 3 angle was supposed to look like along with measurements. If you have small intake runners to keep velocity up, are you allowed to put your heads on a serdi machine and open up the bottom angle as big as you want with a cutter off the valve guide and still be legal under there new any valve job rule? You did not grind, sandblast, acid port, shot peen or anything else, you simply did a fancy valve job on a machine with cutters off the valve guide. Will NHRA tech allow this if the runner cc checks or will this be a gray area judgement call " the famous I don't like the way it looks " I don't think Wade or any of us want to here that phrase anymore.
#7 | |
If I were going to do something like that, I'd "get it in writing from Glendora", and keep it in the notebook that goes with the car.
Alan Roehrich 212A G/S |
Guest
Posts: n/a
Rich, I've heard stories about that car when Spyder raced it, on how unbeatable it was compared to anything else. I've heard that from multiple people over the years. Spyder told me how mad Jenkins was when he sold the car, because he didn't not want other people looking at it. Think there was stuff in the questionable or on the edge? I'm sure. I'm not saying you think the class is bad, just that tech wasn't perfect back then and stuff got by. I will ask Walter about some of this.
Tech has thrown people out for questionable cylinder heads, In fact it has happend this year. I think tech does an excellent job, and unfairly overruled by the higher up due to politics at times. Nothing new I'm sure... QUOTE=Rich Biebel;331831]Maybe you need to check your facts Todd.. The Monster Mash was a 265 in a 55 Chevy with a 3 speed.....Lots of other cars just like it were also fast back than and if any of them had bogus heads like today and set a record they would have been thown the hell out......When we raced against the Monster Mash it was a 14 or 15 second car.... Did guys cheat and bend the rules and get away with it.....Well I am sure they did....but most didn't for fear of being caught. I raced 2 cars from 1966 to 1970. Both were legal and ran pretty close to what most other cars of the day ran or faster. I never said anything was wrong with Stock...... People like myself are just pointing out the way the rulebook is written about heads.... Ask Walter what he thinks....[/QUOTE] |
#9 | |
Liked 595 Times in 136 Posts
I worked around his engines and had conversations with him about the Monster Mash. Though he was always candid with areas he'd stretched the rules in I never once heard him say that about the car in question. Jenkins sealed short blocks tighter than anyone I'd ever seen. Back in the day, I would not have believed his leakdown numbers had I not seen them myself. And as for being angry about the car being sold, you'd be angry too if your entire career had been people copying your ideas that you didn't/couldn't patent. Things like gas ports, cylinder finish, block plates, and everything else he invented to keep blocks sealed. Now extend that sort of thinking to every other process of engine building and you might understand why he didn't need to cheat. |
Liked 120 Times in 42 Posts
