#31 | |
Liked 49 Times in 15 Posts
I was under the assumption that Super Stock was created BECAUSE there was porting going on in Stock years ago. So they created SS so there was a place to put the cars with ported heads. If that's the case, wouldn't that imply that porting has been allowed in SS since it's inception? Welding and the resulting cover up is already happening.
Dean Feiock -- Stock 5002 Last edited by Dean Feiock; 06-16-2012 at 02:16 PM. |
#32 |
You just sent a chill down the spine of every head porter that offers cover up services.
Dean Feiock -- Stock 5002 |
#33 | |
Of course welding and covering up is happening. The problem is, if every time someone cheats, the rules are changed to legitimize that cheat, sooner or later all the rules are changed, and the class no longer exists in the intended form.
Alan Roehrich 212A G/S |
#34 |
Liked 2 Times in 2 Posts
Let's think about this for a minute. Let's say I'm a cylinder head guy and I have a C&C program for a super stock head which is the same cc's for stock. Let's say that after years of working on this I have the best possible runner design you can have for this combo. If I can get the NHRA legal aftermarket aluminum head in a pro port configuration all I would have to do is throw it in my C&C machine and bam!!! Its done. You have what looks like an untouched runner (after cleaning up the C&C marks I guess) and I can now pretty much mass produce this thing. The only catch is getting the casting in a pro port configuration. If I can't get the head in a pro port then I fill in the area's that need filled and then send it through my C&C machine. Am I out of my rocker here or can this pretty much be done now with any aftermarket aluminum cylinder head?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#35 |
Liked 54 Times in 27 Posts
Today's Stock = 1970s SS
today's SS = 1970s Modified Production What's next? |
#36 |
Well you could say today's Comp is like the '70s Pro Stock but they are probably way more advanced than '70 pro stock. Maybe like the 2000's pro stock.
#37 |
I would have liked to had my present SS heads on my old C/SM Camaro. A little media blasting and what we had then could have been a poor set of present day Stocker heads. The aluminiun heads have an advantage there.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-16-2012 at 04:53 PM. |
#38 | |
Valve springs and all !
#39 |
Banned
The W-2 heads that were run in B/SM and C/SM in 76, 77 & 78 were ported and shot peened for Mopar/Hamburger but in Mopar boxes and sent backed to warehouse and sent out to racers. I was helping Fadely in 77 & 78 at Spring Nationals Jim Dale and Jim Fagan sent all the B/SM Fords to tear down at Mayo's place to check out the heads NHRA CC'd the intake ports and measured the ports with dividers and snap garages It was Mike Urley Jim Ellien Jim Stevens and Fadely of the 4 Fadely's were the smallest in volume and bowl dia and short turn height. As I remember the had FJ Smith there with his Chevy.
#40 | |
Liked 3 Times in 1 Post
Wade |
