Old 06-15-2012, 10:59 PM   #21
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Default Re: Stocker Cylinder Heads....
If heads cost $5k + than they're not stock! CR
Old 06-16-2012, 07:56 AM   #22
james schaechter
Liked 1,436 Times in 299 Posts
Consistancy in the interpretation of the rules is key.
There are some improvements that can be made in that area by NHRA.
Here are some issues to overcome:
NHRA officials at a high level tell different people different info
NHRA tech officials do not all agree on the interpretation
NHRA has some very knowledgable tech officials, but many have and will be retiring. There is a serious brain drain and the replacements just won't have the knowledge to effectively police these rules as they are, even if NHRA puts a process in place that would support this.
Time constraints and the desire to shave cost by NHRA limits tech opportunities
Machine Equipment has evolved to the point where there are some pretty nice heads that look good, are fast and will pass tech-but are $$$ and out of reach for many.
There are less clean castings to be had for older stockers
No specs for intake manifolds
I don't see NHRA supporting the tech staff any more than they do now.
NHRA does not seem to be able to recruit the new blood now that could learn from the veteran tech officials to transfer knowledge to them
The time constraints for teardowns are only getting worse
NHRA thinks TD and TS will be the future ( although after Joliet last weekend they might rethnk that LOL)
So what could be done?
I know some who think the clock can go back won't like it, but I think we are at a place in time to make a rule change.
My proposal would be to keep the CCs intact for the heads as a spec
Allow porting, but no filling ( weld, epoxy, etc) allow intake port matching, but no filling
Look, I saw a lot of cars pick up .2-.3 over the winter and it ain't from jetting and timing.
I think that the porting won't have the negative effect that many have said. ( as long as it is allowed up front) The price will be less and many racers will try their and learn on their own.
I believe there is more $$$$ being spent covering up the work that is and has been done than the actual port work $$$.
I say we call it what it is and level the field out some. If we don't we will continue to get what we got.
I am not saying it is perfect, but we are at the point where something has to change.
I don't see NHRA putting more time, money and thought into this. If the process of enforcement isn't easy, it won't happen in most cases.
James Schaechter 3163 STK
Old 06-16-2012, 09:38 AM   #23
Chuck Norton
Liked 89 Times in 19 Posts
Nicely stated, Jim. You've put your finger on a number of very real problems and offered reasonable solutions.
c
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 06-16-2012, 09:48 AM   #24
Pvt Parts
Pvt Parts's Avatar
Correct. From a money standpoint, I think NHRA sees Stock and Super Stock racers as just another competitor in the gate. From an overhead standpoint, these racers bring a lot of baggage.
Old 06-16-2012, 09:58 AM   #25
Bobby Fazio
Bobby Fazio's Avatar
Originally Posted by Ed Fernandez View Post
When Vinny Gumbotz did my head many moons ago he guaranteed they'de pass tech anywhere,anytime.
Dr. Vinny Boombotz did your heads? Did you clear that with Rodney D?
'65 Mustang SS/L & L/SA
Old 06-16-2012, 10:23 AM   #26
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Yeah,Rodney said Vito said it was OK.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 06-16-2012, 10:42 AM   #27
69Cobra
Liked 2 Times in 2 Posts
I think you made some very good points Jim. As some one that is currently spending a lot of money to get in to this game I don't want to be DQ'd by a tech's opinion. To me it needs to be cut and dry. Allowing the porting to the cc limit and the port matching of the intake will eliminate a lot of grey areas that everyone that runs fast flirts with anyway and the racers wouldn't have the cost of whatever it is to cover up the work that they've done, which would make it cheaper on some one like me who is starting from scratch. Just my .02
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 06-16-2012, 11:17 AM   #28
Porting opens up a whole new can of worms.
If you can port, you can cover up almost any amount of welding, within reason. You don't even have to resort to acid, or media blasting, anymore.
Once you get them to allow porting, you'll never get them to go back.
One of my best friends, who is a really good cylinder head guy, said the worst thing they did was to allow porting in Super Stock.
I really can't see where the result will be better in Stock Eliminator.
Of course, the roller rocker rule may be the precursor to porting.
It may accelerate the switch to "aftermarket" aluminum cylinder heads. Because welded iron heads always crack, it's just a matter of when. It's much easier to weld aluminum, and easier to cover it up. The supply of iron heads will dry up even more quickly, and more cylinder head guys will prefer aluminum heads anyway.
Old 06-16-2012, 01:24 PM   #29
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
That same guy told us that one evening at a ihra race in Huntsville back in 1997-98 !!! He was right and has been about a lot of issues here...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is online now   Reply With Quote
Old 06-16-2012, 02:03 PM   #30
69Cobra
Well I guess you've got a point there.
Kris Rachford
C/S 3032
