Liked 2 Times in 1 Post
GT/TB Record Holder 9.82 @ 132.82 with 360 small block. This truck was built by Phil Mandella of PMR Race Cars and debut the 1999 Winternational and won Best Engineered. This Truck was also # 1 qualifier at the 2000 U.S. Nationals in Super Stock and most recent # 1 qualifier at the 2009 Winternationals and also WON the eliminator at the 2009 Winternationals. This truck will win "CLASS" anywhere in the county and is a proven National Event Winner. This truck Has the absolute best of everything and is completely science out. Many spare parts go with the truck.
The chassis was built on a jig by Phil Mandella and is built using all chromolly tubing with a funny car cage. Lamb components 4 wheel disc brakes that have been all freshened in 2009 Ford 9 inch rear end MW heavy duty aluminum third member with new back cut rear gears and scalloped steel spool in 2008 set up by Lamb components 40 spline and gun drilled MW axles Rear shocks are Koni coil over from Lamb components and Dyno tuned by Roger Lamb New fuel system and replaced all hose in 2009 New aluminum radiator in 2009 New CSR water pump in 2009 New MSD Digital programmable ignition system New front tires with 1 new spare tire and wheel in 2009 New Rear Tires And 2 Spare tires and wheels 1-2 & 2-3 Air Shifter (Dave Smith) PRO TRANS ROLLERIZED 904 ALL ALUMINUM FRONT & REAR DRUM WITH TRANS BRAKE Munsinger 8 inch Torque converter 3 gallon fuel cell custom aluminum bed cover Custom OIL PAN from Billet Fabrication Custom headers from Dawson Headers and ceramic coated with O2 sensors in each tube Mark Williams Removable steering wheel Custom Drive Shaft from Inland Empire Drive line with new u-joint in 2009 This truck has been maintained meticulously and is in as new condition. $30,000 Turn Key OBO. Call Shane Studley @ 714-401-7405 for pics go to www.autoimagery.com and type in my name. Last edited by Shane Studley; 06-12-2012 at 06:26 PM. Reason: add photos |
