Liked 3,193 Times in 975 Posts
Good advice here...after running it to full operating temp I'd definitely do a leak down. After sitting 8 years you'll be lucky to get off without tearing it down. If the leakage isn't too bad it may not be able to RPM due to weakened springs. Like Bobby, I'd be curious where you're located, you probably have a racer close by to offer some guidance.
