#51 | |
Liked 184 Times in 113 Posts
But closer to the advertised Compression Ratio. Deck Block to Minimum Rating, .030/.070 Overbore, .015 over Crank. The Overbore helps unshroud the Valves and breaths little better. But cannot see more than a 1/2 point increase in Compression. Maybe wrong ..my 2 Cents !! Still 93 Octane runs well in my LT1. Which has 10.5 to 1 Compression and running 36 degrees Timing. Figure that 100% gasoline would run a better ET than 10% Methanol Blend. Because the Methanol reduces the BTU produced... My 94 Caprice LT1 Wagon seems to have lost 1 mpg in cruising. Tougher to get 24 mpg, getting more like 22 and 23 mpg fill ups. Dan |
#52 | |
![]() That car is one of the top three on my if-money-were-no-object-what-car-would-I-race, list...the '68 Dodge Dart Hemi, and the '64 Plymouth Savoy, being the other two!
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#53 | |
Some of those cars could be ready to buy and race and in showcar form. All would fit right in and many are full up restorations. PureStockDrag rules are almost identical to IHRA Pure Stock. Only minor changes are needed if at all. Many already have gone through tear down to validate their records. These guys are tough, here are the rules. http://www.purestockdrags.com/index....d=48&Itemid=53 Many of these cars would own IHRA Pure Stock Records. Plus they would add a huge mystique what the originals actually ran. IHRA (hint--hint) there is a whole Pure Stock market ready for you to invite... Dan |
#54 | |
Liked 69 Times in 30 Posts
#55 | |
Liked 372 Times in 130 Posts
http://fastraces.org/ The " pure stock drags " races I have read about are the most legit pure stock class I have ever seen:
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#56 |
Liked 46 Times in 29 Posts
yeah, 2 different classes. Cheaters areeverywhere, can't help that tho, to a point.
Should get my Buick done for pure stock. what would a 1970 Buick GS w a 455, small valve motor be classified in, and at what weight.It is a tank. |
#57 |
Chris, they're not cheaters just people taking it to the limit. It does not say that the radio has to be.working. Like Smokey Yunick said many times, if you're not pushing the enveloppe, you will never move forward. This is the reason for having strict rules.CR
#58 | |
Those Pure Stockers have really strict rules and go through an full NHRA like Teardown to claim their ET records. AND not for Money ....they do it for Bragging Rights !! As for the 1970 Buick...should fall in B or C Pure Stock. Contact Mike Baker for you combination. AND Check with Dick Miller on suspension upgrades to make it hook. D Last edited by Dan Fahey; 05-23-2012 at 02:13 PM. |
#59 |
BTW..who is running the Pure Stock Web Page now??
#60 |
Liked 251 Times in 125 Posts
If I remember right, NHRA started requiring race gas because pump gas wouldn't check.
Pure Stock would only happen at NHRA events if there was something in it for NHRA. |
