#21 | |
As I understand this, we're talking about measuring the head of the valve. If so, I for one would like to see Mopar's Magical Mystery Technique for acquiring this measurement. Sounds more like.... "put any size valve in it and we'll issue the paper work to cover your arse."
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#22 |
There were numerous tech spec errors on the first generation Drag Paks in 2009.
We kept waiting for next tech bulletin: Titanium retains; not allowed. Piston dome height; wrong Rocker arm ratio: wrong etc. etc. But we knew what the specs read. And where necessary, we got parts like the piston, that matched the specs. And since in the case of rocker arms, there weren't even any after market parts even being made. So stock factory rockers were all that we could run. And we just ran them and hoped. Finally all of the spec wrinkles on the 2009 were ironed out. But, as hard as the guys at the Drag Pak project at Mopar worked, there aren't enough of them, nor is this their only project. I am not offering any kind of excuse for their oversight on the spec. It shouldn't have happened, but I can see how it did. David The New Hemi Guy Last edited by NewHemi; 05-07-2012 at 11:35 AM. |
#23 | |
Hey all those things are understandable but the bottom line is that this is NHRA drag racing, not Mopar factory racing and if the parts don't meet the NHRA specs, they are not legal.
#24 |
Liked 2 Times in 2 Posts
In my case there were no piston specs for the 392 till March of this year. My engine was built with Diamond pistons as per NHRA specified with NHRA Logo and Diamond pistons engraved on top (early Drag Pak pistons had no engraving on top that was added after the first ones went thru teardown). There was no part number or ring spec in book til this March. My engine builder only had what was available for specs last June when my engine was built. He trusted Diamond to build pistons per NHRA as they were a approved vendor.
#25 | |
Liked 1,929 Times in 434 Posts
Irv, are you saying NHRA allowed you to race a car with an engine that did not have clearly defined specifications in the blueprint guide? How did they expect to properly inspect an engine at tear down if there was no published specification, or even an accepted part number? The blame for that lays solely at the feet of NHRA.
Alan Roehrich 212A G/S |
#26 |
Liked 175 Times in 78 Posts
Not unusual for the newest cars
Our V10 was the same deal - that is why I dislike someone accusing the engine builder of being stupid or us not doing what we should have The engine builders did the best they could and so did we BTW so did the factories and NHRA Now all of the jealous haters can jump on that but I will say "Elvis has left the building" - LMFAO
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
#27 |
[QUOTE=Alan Roehrich;324543]Irv, are you saying NHRA allowed you to race a car with an engine that did not have clearly defined specifications in the blueprint guide?
How did they expect to properly inspect an engine at tear down if there was no published specification, or even an accepted part number? The blame for that lays solely at the feet of NHRA.[/QUOTE Not exactly , we didn't find that out till today there were no specs on Diamond pistons in the 392 until March all the other specs were posted, ie: bore, stroke , valve size, cam, deck, head gasket thickness, throttle body size.rockers . |
#28 | |
Art Leong 2095 SS |
#29 | |
I've been through the approval process for various approved Stock Eliminator parts. Never once did NHRA offer to let me run a part that either had no spec, or had no published spec, or did not have the required approval number on it. In fact, I had two new sets of approved pistons with the correct part number, in my hands and ready to go into the engines, when NHRA rescinded their approval over 0.005" of dome height, when the piston did in fact have 0.001" less dome height than the maximum allowed. NHRA came back and told us the pistons were not approved, had to be remade, and resubmitted. I waited 6 months to get my pistons the first time, then 3 more months. Both times NHRA had my parts in their possession for an extended period of time. So no, Ron, I do not buy the idea that NHRA and the OEM did the best they could. They held me and my piston supplier to a far higher standard. I never got to race a part that wasn't listed and did not have a spec in the guide. No, they best they could do is for everyone to go through the same process and be held to the same standard.
#30 |
Liked 12 Times in 12 Posts
