I suspect you have a an IC fairly close to the rear end of the car to maximize your bite to break the beam quickly. Without knowing where that is, the following should apply: Move IC out for a higher horsepower application. As the HP goes up, stiffen the extension on the rear shocks to slow down body separation and provide a longer application of useable leverage.
