Old 04-26-2012, 12:56 AM   #1
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: 502 Ram-Jet Crate Engine Bracket Racer ?
Originally Posted by 1320racer View Post
20 years ago my 4000+lb. streetcar/show car Chevelle with the stock 396/350HP under the hood was running mid 12's with a Q-Jet and through a full exhaust system.
16 years later and the year it was sold, the same all steel show quality car, now tipping the scales at 3880 lbs., still with power steering, power brakes, tilt wheel, full factory interior and a full exhaust under it ran well in the 9's with a restrictor plated 522 under the hood as well 137 MPH and wasn't backed by a $6,000 trans nor run in -500 feet air either.
9.89 @ Disneyland, with a aftermarket 522 @ 134 LOL in negative 1800 air, 30.4 baro, LOL LOL AW.
Old 04-26-2012, 01:00 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
still trying to peddle that lie?
Old 04-26-2012, 01:02 AM   #3
HP HUNTER
1.28 60, still trying to peddle that lie, post the time slip, but you cant, can you.
Old 04-26-2012, 01:06 AM   #4
1320racer
1320racer's Avatar
sure I can, got the time slip right here and so does Bret but it's much more entertaining watching you beg for it cause team clueless's mascot with your junk under the hood ain't matched it no mind done better with more power backed by a $6,000 trans in a car that weighs at least 300 lbs. less and was run in -1600 air!
Old 04-26-2012, 01:08 AM   #5
HP HUNTER
sure I can, got the time slip right here and so does Bret but it's much more entertaining watching you beg for it cause team clueless's mascot ain't done better with more power backed by a $6,000 trans in a car that weighs at least 300 lbs. less and was run in -1600 air!
More lies and misinformation, you got no time slip, everyone wants to see it.
Old 04-26-2012, 01:12 AM   #6
1320racer
1320racer's Avatar
no they don't, only you want to see it cause you refuse to believe cause you and your boy ain't done it with more of everything meanwhile both Joe Abbazia in his B/SA '71 Chevelle and Kevin Borgstrom in his B/SA '69 Chevelle have both run 1.29 60 foot at least 5 years ago too, with less power under the hood, weighing less than my car and with more gear.
Old 04-26-2012, 01:19 AM   #7
HP HUNTER
I spoke with Joe Monday, and well lets just say he wants to see it to, and dont compare your junk to Joes 71.
Old 04-26-2012, 01:13 AM   #8
HP HUNTER
Current weather information* for
Atco Raceway in Atco, New Jersey
  • temperature = 41.0 deg f
  • relative humidity = 79 %
  • uncorrected barometer* = 29.84 Hg
  • corrected barometer* = 29.93 Hg
  • density altitude = -947.09 ft "Disneyland"
Old 04-26-2012, 01:17 AM   #9
1320racer
1320racer's Avatar
whose racing at Atco now at 1:18am?
