Old 04-25-2012, 10:32 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: 502 Ram-Jet Crate Engine Bracket Racer ?
I did say oil pan to carb and I kn ow what's required to get an honest 800HP out of a 496.
That said, you'd have a hard time convincing me and many others that you build/sell a 468-496 using factory castings that makes 800HP, proved on the track for $11K.
Old 04-25-2012, 10:37 PM   #2
HP HUNTER
Liked 372 Times in 129 Posts
Originally Posted by 1320racer View Post
I did say oil pan to carb.
We know Johns been 138.3 @ 3615 in 800 feet air with no tuning with 32 degrees timing, this 10.7 compression engine made 774 on my dyno, I think its shows the power, another point of compression pushes it over 800. I wouldnt want to include the carb for 11,000.
Old 04-25-2012, 10:47 PM   #3
1320racer
1320racer's Avatar
1. 774HP ain't 800HP
2. we only know what he and you have stated and both you have a reputation not telling the whole truth. least of which is like his engine is backed up by a $6,000 lite weight trans and the air was more like -500'
3. this ain' the op's question or topic
Old 04-25-2012, 10:55 PM   #4
HP HUNTER
2. we only know what he and you have stated and both you have a reputation not telling the whole truth. least of which is like his engine is backed up by a $6,000 lite weight trans.
Im very confident that on any calibrated SF 901 dyno, correcting @ 29.92, 60 degrees dry air, 0 humidity, I can make over 800 HP through my mufflers. And I would back it with big money, I guess thats all I can say. John trans is a 3000.00 trans. So if you run 131 in your chevelle, claiming 700 HP, how much HP does it take to run a 138.3 @ 3615-3630, fair question Ed. It would be interesting to see Johns car with a forward facing hood scoop, I believe we will see a 140 when he gets it dialed. John ran some tire spinning 138.3 MPH runs a week ago in 800 feet air.
Old 04-25-2012, 11:03 PM   #5
1320racer
1320racer's Avatar
as I have stated and proven before, his trans can't be bought for $3k used no mind new...
http://www.racingjunk.com/Transmissi...and-parts.html
just one of the many lies and misinformation posted about this car and it's performance on the net.
If you want to continue to debate it, start another thread.
Old 04-25-2012, 11:05 PM   #6
HP HUNTER
Old 04-25-2012, 11:10 PM   #7
1320racer
1320racer's Avatar
http://classracer.com/classforum/sho...light=Coan+XLT
