Liked 68 Times in 41 Posts
You will still need 4 points to get in if they raise the quota.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Only until the quota opens up for three. There was a rule change I believe. If it closes at 4, than add more spots, if 3 can get in than its open for them too! Might be confusing. So really if they add spots a person with one grade point could potentially get in if it was full at 3 (or any number)
Michael Epprecht - Division 1 - B103 |
Liked 886 Times in 238 Posts
They need the extra acre Alcohol would have taken for the Traxxis radio car display!
#4 | |
Liked 460 Times in 91 Posts
lmfao !!!!!!
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 1,307 Times in 399 Posts
Tom....That's a good one and I even haven't had my 1st cup of coffee yet!!
I used to race up there and that race always had 128 Stock Eliminator car field. I guess with all the big rigs that people have now, it uses up pit space and takes away entries. That used to be the best race to go to, even when it was 130 degrees in the pits.
Stock_B103, I pushed NHRA so much about the grade points and not allowing someone with less grade points to enter a race if there where openings, that they changed their policy about it. Their policy was school yard mentality until they changed it, now it is correct. If there is a withdrawl, they allow other racers to enter with less grade points at the given grade point window. They changed it after it was too late for me to enter the Gators. Casey Miles 248H "F" NHRA Stock! |
