Liked 520 Times in 132 Posts
Ed Carpenter 2005 Chevy Cobalt A/SM Race Engine Development Last edited by Ed Carpenter; 04-19-2012 at 08:12 PM. |
#2 | |
Maybe at this point some dyno time might be a good investment.????
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#3 | |
Liked 1,877 Times in 422 Posts
Alan Roehrich 212A G/S |
Ed
What did you find wrong with the motor. When I talked to you in San Antonio, you said the leak down and the compression test didn't look good.
Alan Warman STK 4107 |
Liked 77 Times in 39 Posts
I had a problem like that years ago when I had my chevy ll after weeks of tearing my hair out turned out to be a bad msd box. It didnt miss breakup just no power going down the track.
A really bad ground? New MSD box incorrectly wired on installation? Can you borrow another box after you check your grounds and installation?
Jeff Lee 7494 D/S '70 AMX |
Liked 52 Times in 9 Posts
Replace pickup with a known good one. better yet put new one on.
Jim Morgan 1916 , 9916 STK |
Liked 275 Times in 76 Posts
Is there a chance that the polarity to the distributor pickup was switched? That is all it takes to do some strange things with the MSD. The car will run fine, until going down the track, and then it will act like the rev limiter has been lowered. Good luck.
Sean
Liked 163 Times in 53 Posts
I agree with Jim, change the pickup. we had that same issue at a race a few yrs ago and change the pickup and the car ran fine!!
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 320 Times in 102 Posts
Just some random info about MSD's & other high current draw parts...............
The MSD 7AL depending on the resistance caused by the plug gap, high compression, rotor gap, sparkplug wires, load, RPM and anything else that makes it more difficult to fire the plug will raise the amperage requirement for the box. Your power supply wiring should be capable of passing 15 amps on the positive AND negative side..... All wiring connections should have crimp fitting (mechanical connection) and be soldered (electrical connection) and be covered with shrink tube to prevent corrosion..... You MSD box will work perfectly until you the reach the point of needing more amps than your wiring can supply... Had the same type of problem with a MSD 404 box 40 years ago and learned my lesson regarding resistance in the power AND ground side of wiring.. In the words of Stroker McGurt "If some is good, more is better and too much is just right" Hope this helps, Bob
