Old 03-27-2012, 03:34 PM   #1
Brina Splingaire
Smile Parts for Sale
Jesel Pro Series Rocker Arms for a SBC
-Brand New, individually wrapped in the box
-Intake part # IRR-01001, number on rocker BABR80
-Exhaust part #ERA-01001, number on rocker BAAS70
-$900
Manley Rods for a BBC - Used
-"H" Beam Rods
-Part# 14062-8
-Center to Center 6.385"
$200
Be Cool aluminum radiator w/ fan
-fits Firebirds/Camaros.
-$500
1050 Bob Book Carb for Sale
-Gas Carb
-Rebuilt Spring 2011
-Great Condition
-$950
400 SBC For Sale
-done by Brian Tilburg Engines
-632 HP
-Approx. 40 runs.
-Ran 9.93 at 3250 lbs in a 2000 Pontiac Firebird
-MSD belt drive distributor
-ATI dampener
-Danny Ashley Quadra-Jet
-Ran in NHRA GT Super Stock class but can be used in other classes.
Last freshened in June 2011.
-Updated cylinder heads
-new Crower lifters
-new Jesel rocker arms with roller tips
-new 50 mm camshaft
-new Manley valve springs
-new Pac retainers
-new valve locks/lash caps
-new exhaust valves
Asking $12,500. We just put $8,000 in to have it freshened. It is a very reliable motor in great condition!
Trans Specialties Converter for TH350
-6000 stall
-$400
Wilwood 3/4" master cylinder
Part #260-1304
Asking $40.00
Aluminum CSR Oil Catch Can
-$75.00
MSD Ignition 8735 MSD Launch Control Module Selector
-Brand new in the box.
-$150.00
Barry Grant Paper Fuel Filter Replacement for Gas engines
-Brand new in wrapping.
-Asking $15.00
Barry Grant Wire Mesh Fuel Filter Replacement for Alcohol/Methanol engines
-Asking $20.00
Barry Grant Inline Fuel Filter
-Brand new in box.
-$100.00
Chrome Aerospace Components Oil Breather Tank
-$125.00
Chrome Mechanical Fuel Pump Bracket
-$50.00
Digital Delay Digital Viewer
-$150
http://www.racedigitaldelay.com/delay-digviewer.html
Rossler Trans
2.27 gear ratio
steel internals
powerglide input shaft
reverse pattern with clean neutral
transbrake.
This is a Rossler trans freshened by Coan. I have not made any passes on it since we had it freshened.
All new below from Coan:
standard pump assembly
sungear/output bushing
pan gasket
pump to case gasket
TH350 pump to case o-ring
direct pressure plate
pump shim
clean neutral valve body kit standard brake
-$2500
Pictures or questions please e-mail splingaire4@gmail.com.
Brina Splingaire is offline   Reply With Quote
Old 03-27-2012, 06:10 PM   #2
3713kv
Default Re: Parts for Sale
hi do u no rocker ratio for exhaust and intake and do they have shafts and bolts thx
3713kv is offline   Reply With Quote
Old 03-28-2012, 11:42 AM   #3
Brina Splingaire
The rockers have the shafts but no bolts.
The ratios are 1.80 and 1.70. The last two digits on the rocker arms are 80 and 70. Those denote the ratio. If you PM me your e-mail I can send you a Jesel Rocker Arm code chart and a picture of one set of the rockers.
