Old 03-12-2012, 08:36 AM   #3
philbilly
philbilly's Avatar
Default Re: Chevy 2 rear leafs??
Originally Posted by Jim Cimarolli View Post
Sounds like you need to change the spring cup, the washer did not serve to center anything.
It may be the spring cup as you say. Looks like a freeze plug with 7/16 hole in it. it is about 2 1/2 inches round. Sure looks like it does the centering. I did use the term washer because i have no clue what it is actually called. Is there a replacement part?
philbilly is offline   Reply With Quote
