Old 03-09-2012, 02:13 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Suspension set up Chevelle
Front suspension has got to be right before worrying about rear suspension. What is it besides the QA-1s?
A Chevelle at 3000 lbs., is pretty cut up so 50/50 should be doable.
That said, my 3880 lb. Chevelle was 59% front/41% rear and ran in the 9's launching wheels up every pass.
What is the rear suspension is in it now? Footbrake or transbrake launching?
Some preload on the right rear is required, which will put more weight on the left front.
Make all adjustements with you in the seat.
Old 03-09-2012, 04:33 PM   #2
shockme668
shockme668's Avatar
Front is chrome molly tubular control arms, wilwood drag brakes w/vented rotors and double adjustable coil over shocks. Rear is strange coil over double adjustable shocks with a anti roll control. It has a 400 trans with a trans break. I think about 3000# maybe 3200#. wont know till I weigh it. It also is a big block with solid roller cam.
shockme668 is offline   Reply With Quote
Old 03-10-2012, 10:00 AM   #3
1320racer
1320racer's Avatar
Has stiction been eliminated in the front A Arms? How much travel do you have? Are the springs the correct rate for the weight over/on the front tires? Is the front end sitting at the correct ride height static?
Old 12-18-2012, 09:50 PM   #4
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Looks like an Alf Weibe set up to me
Kevin
