Phillip, there is nothing inherently wrong with HJC, other than it being M rated. If the helmet was truly not dropped or damaged, and was in fact an HJC, then you got an excellent deal on a marginal (in my opinion) helmet. Some Simpsons are made in the US (hat sized). We get enough questionable products from China, that I would not trust a helmet from there. Another note about M vs SA ratings, some manufacturers make both M and SA versions of a particular model helmet. In that case, the fire retardant lining is often the only difference, however there is more than that to the difference between M vs SA
Chad Rhodes 2113 I/SA |
#2 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
In most cases you are correct Jim, but I was told by a Simpson rep several years ang that the difference between a M rated voyager and an SA was just the lining. So for those looking to save a dollar, it might be a question worth asking.
#4 | |
#5 | |
Liked 282 Times in 103 Posts
What exactly makes HJC helmets marginal? And if you are so concerned with safety,then I'm sure you also wear a Hans device? |
Actually I don't wear a hans. Without a proper race seat (which NHRA won't allow us in stock), it would not be very effective as it uses the belts to secure it and the padding in a stock seat has too much give.
And I said marginal, when I should have said lower end. I've never been impressed with the quality of them.
"Since 1971, HJC has specialized in manufacturing motorcycle helmets exclusively. The combination of this extensive specialized manufacturing experience, innovative ideas, and reasonable pricing resulted in HJC’s success in worldwide markets. It is HJC’s continual goal to provide high quality, comfortable, and reasonably priced helmet to motorcyclists around the world.
As a direct result of this mission, since 1992, HJC has succeeded in maintaining the status as the #1 helmet brand in North America. (Refer to Motorcycle Industry Magazine 1992-present) More importantly, motorcyclists worldwide make HJC their brand of choice. " Thanks for the offer Jim but I think the HJC will do the job it is intended for.
2009 V/SA Record Holder |
