Liked 18 Times in 10 Posts
NIB..Hughes Performance GM94 Pro IV 9" Race Torque Converter..Fits Powerglide w/TH350 input,TH350 and TH400. This was spec'd for a race bigblock w/glide,was told would also work well with a stroker smallblock.
This is off Hughes websight: Hughes Performance TH350/TH400 Pro-IV Race Torque Converter Pro-IV Series are more aggressive by design. The units are normally good for slightly higher MPH. Units are designed with more furnace brazing which produces less efficiency loss and less slippage, therefore producing higher miles per hour. This unit will still produce excellent repeatability, a must for bracket type race situations. Anti-ballooning plate Full roller bearing construction Custom machined heavy duty stator Heat treated sprag race Fully spot brazed and reinforced impeller assembly Fully spot brazed and reinforced turbine assembly Heat treated forged steel turbine spline Heat treated chromoly steel pump hub Fully welded mounting ring Pressure tested Computer dynamic balancing $800obo shipped to your door in lower 48..These are $1050 new from Summit. Call with other questions. 208-965-0664
Gordie Kissner SS 6010 STK 6010 Last edited by Gordie Kissner; 03-06-2012 at 03:30 PM. |
