#21 |
Wife & three kids
#22 |
Sponsor
Everyone's ideas on here are good for removing decals. Before sticking new ones on, consider this.
Go to a sign shop and see if they will sell or give you some static cling vinyl. Stick the decals to the static cling then cut out around the edges of the decal. Now stick the decal on the car. You will be able to move the decals around remove or reapply them easily. I have been doing this for years. It is a little work to apply the decals to the cling-on vinyl but nothing compared to peeling them off without using static cling.
RacingRicki |
#23 |
Liked 71 Times in 23 Posts
After hair dryer and removal, I always use goo gone to get the glue off.
Apply the goo gone stand back drink a beer then wipe off, if needed after you let the goo gone set for 5 minutes you can use a rag and plastic razor blade works excellent
Monte Howard 3209 STK, 3208 SS Last edited by Monte Howard; 02-24-2012 at 09:27 PM. Reason: Spelling |
#24 | |
Liked 251 Times in 125 Posts
#25 |
Liked 100 Times in 45 Posts
Angelo,just invite Billy Nees over and buy him a bottle of Cuervo Gold and some sauerkraut.He'll either blow on the decals and they'll just drop off or the kraut is for plan B.
Can't guarantee the paint will survive Plan B though.Oh yeah,open the windows and have a milsurp. gas mask available.I hope that helps.Plan C is to invite Himes over too.
Former NHRA #1945 Former IHRA #1945 T/SA |
#26 | |
Liked 427 Times in 97 Posts
Test a small spot on whatever surface your trying to remove the decals on! Nick tried to remove "painted lettering" from a trailer, the oven cleaner not only removed the lettering but the paint from the panel as well...... Oven cleaners will streak and dull the finish if left to penetrate for a long period of time! |
#27 | |
Liked 451 Times in 77 Posts
Angelo, 3m makes an adhesive remover that wont harm the paint and will take the glue residue off. Heat gun on low always worked for me on the stickers. |
#28 |
#29 |
Liked 14 Times in 10 Posts
[QUOTE=Monte Howard;311335]After hair dryer and removal, I always use goo gone to get the glue off.
Apply the goo gone stand back drink a beer then wipe off Repeat as needed! |
#30 |
Liked 6 Times in 5 Posts
After the old ones are off, put a dozen or so coats of wax on the car to make removal easier next time.
