Old 02-04-2012, 01:37 PM   #17
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Stocker Crankshaft Heavy Metal
Originally Posted by Adger Smith View Post
Question:
How is it going to be "determined", proof beyond any doubt, that you have a 305 crank in a 350 when the casting numbers are identical?
I know an identifiable difference, but I'm asking the question for legal tech purposes.
Not being a tech man, I neither know or care about the procedure to determine if the crank is legal or not. The fact that someone would go the expense and effort needed to convert a 305 crank to a 350 application, when 350 cranks are a dime a dozen, leads one to believe that there is an advantage to doing so. A similar advantage could be had by using a lightweight aftermarket crank for the 350, a huge variety of which are also a dime a dozen. In either case, their use is ILLEGAL and that is THE POINT. The rules are there, they are clear enough and anyone who ignores them or thinks they are just "bending" them to gain an advantage is a CHEAT. PERIOD.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
