Old 01-24-2012, 04:34 PM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Re: Rocker Clarification is up!!!
Originally Posted by Alan Roehrich View Post
That's not directed at you, personally, Aubrey, but rather a general statement.
Yeah ? YEAH ? !
HEE HEE !
maybe I know less than that ?
I'm just sayin... It seems to me that much of the reason NHRA removed the spring pressure and duration rules, was to simplify inspection and enforcement. Of course it changed things. This rocker allowance can be simplified too. Merely have a ratio tolerance... IE; +/- .05, and if lift at valve checks ok... we're good.
I understand that "ingenious" folks may discover advantages one way or another. Positioning of the fulcrum-point for one. Shaft rocker setups are probably more stable, but stud rockers are more user friendly.
I dunno
maybe I'm just simple ?!
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-24-2012, 05:29 PM   #2
Liked 1,831 Times in 415 Posts
There already is a rocker ratio tolerance, it is +0.0/-x.x, as they don't seem to penalize anyone for not having enough ratio. You can have the stock blueprint ratio, or less, but not any more than stock. That's tolerance enough, a + 0.0/-x.x is an industry accepted tolerance range.
NHRA checks lift at the retainer, then divides by lift at the cam to get rocker ratio. I'm allowed 0.520" at the retainer, I run 0.518", with 0.306" lobe lift on the cam, for a 1.69:1 rocker ratio.
In Stock, we have to use pushrod length to correct lift, in most cases. That does not change, it's just that with aftermarket roller rockers, you'll need to start from scratch, and get the pushrod that gives you the correct lift, without exceeding the allowed rocker ratio.
