Old 01-24-2012, 12:59 PM   #19
Jason
Liked 6 Times in 4 Posts
Default Re: Rocker Clarification is up!!!
Forget the ratio stamped on the rockers. Those numbers evidently mean nothing. Be sure to measure the lift at the retainer AND at the lifter so you can do the math when you check the ratio of the rocker arms yourself. What should be a simple bolt-on is turning out to be a real cluster that no one ever expected.
Remember...watch what you wish for, it might just come true!!!!!
Jason is offline   Reply With Quote
