Old 01-23-2012, 09:02 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: dropped center link
what was wrong with the driveline angles?
I spent no time trying to get the driveline angles "right".
Used the stock trans mount and crossmember as well the Moroso motor mounts mentioned. IIRC, the engine/trans was 3 1/2" degrees down.
Seemed to work well, running a best of 10.07 n/a and 1.28 60 foot, launched off the footbrake and through a full exhaust with a cast iron oval port headed 11:1 468 backed by a stock gearset turbo400 in my 3880 lb. Chevelle.
