Liked 4 Times in 3 Posts
the engine is in the stock location front to rear but the trans has been moved up in the back to correct driveline angle. i dont want to raise the engine.. ive spent alot of time getting the driveline angles right as well as the crank heighth is a bit high. dont want to make it worse.the car has a front and rear engine plate.looks like my options are modify the centerlink, the pan orput a rack in it
