I've been looking at some stick shift Nova's on YouTube, and boy are these screaming little small-block cars cool or what!? However, it got me kinda curious. I noticed these cars are raced in SS/H, SS/I, SS/J, SS/K and SS/L. How is this possible? The 283 and 327 are two combinations, right? What are the others?
Sorry if it's a stupid question, but I'm not a racer and I don't have a rule book. Strittan |
Liked 520 Times in 132 Posts
The Chevy II's and Novas that run in G,H and I are the 327/275 combos and the cars running in J,K and L run the 283/220 for the most part. I know a few that run the 327/250 combo also in J. Hope that answers your question. Ed
Yeah, thanks for the answer.
1963-67 chevy novas came with 283"and 327" engines. They also came with 4 and 6 cylinder engines. Maybe I'm looking at the rules wrong, but doesn't a 327" 275hp combo fit into F,G, and H in a 66 or 67 chevy II?
4878 SS/GA 66CHEVY II |
Liked 12 Times in 4 Posts
Larry Stewart Jr./Sr. run their '67 Chevy II 327/275 in F and G the last couple of years.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
Is Larry's car a 66 or 67? A 67 is a natural "E" car, so I'm not sure how he runs it in "G". The 66 has a better weight break and is a natural "F", so then it could run "G"
Don Fardie 1582 F/S B/G |
Liked 5 Times in 5 Posts
The 1966 327 automatic supersport trim cars fall into H. The non supersport 2 door coupe falls into G. 1967 327 automatic supersport trim and non supersport 2 doors both fall into G. Either can go up or down a class.
Jeff Myers SS3254 S1522 |
The Chevy II that Larry and son run is a '67. Class guide lists it:
NOVA SS Auto Stick Coupe 2 Dr (Sport) 9.28 9.53 S/SS Factor 275/307 275/299 w OEM heads Making it a natural G car SS/G 9.00-9.49 and since you can move up or down a class it will also make F and H.
Liked 759 Times in 109 Posts
The 327/275 hp combo in an automatic is factored @ 307 in an automatic and 299 in a stick. Larry jr. has a '67 SS; however he uses a replacement head which believe it or not is only rated @ 304 due to the fact that the extra 5hp added for replacement head is only since the rule was implemented which the combination was at 299! A little crazy to comprehend but correct. Cars that run F stick or auto are usually post cars due to them being physically lighter. Larry might run F; however I can guarantee he's not even close to minimum! A '66 or '67 SS fits G with some hard work on lightening the car but will easily get to minimum in H with minimal and properly placed ballast. Any way you put it these models are in the top 5 all time for true SS'ers. Stick or Auto, cool either way!
#10 | |
