I have a 2003 Haulmark Thrifty and the front of the roof has a hairline crack.The crack is in the corner of the plastic/composite nose.Does anyone have any suggestions on how to repair this inexpensielvy?
Liked 216 Times in 77 Posts
Drill a small hole at each end of the crack. This will help keep the crack from spreading any more. Then cover the whole crack up with RV roof sealer. You can buy it in a caulking gun tube for about 8 dollars at a RV dealer. This is not the "right" way to do it but its cheap, quick and will keep the water out to prevent more damage.
#3 | |
Liked 6 Times in 4 Posts
Call Haulmark and order a new piece and replace it. But thats not inexpensive (if you have ever had to buy a part from them you know what i mean). If its not too bad it might be able to be repaired by a good body man but thats not going to be inexpensive either. I put the "right" in there so someone did not rip me a new one for what I was suggesting to do. I have done it the way I suggested in the past and it worked (crack stopped spreading and water quit coming in).
Thanks Rob.The entire nosecone was replaced by Haulmark in 2005 while still under warrenty.They said the original was defective and the new one was from a different supplier.Your suggestion will get me threw the winter.
Liked 1,981 Times in 597 Posts
Camping World has some peel-n-stick patches for RV roofs that should work real good for that fix. I used one on my toter roof to repair a small hole that was from squirrels. Clean and stick the patch. Then you could paint the patch to match a little better.
Mike Pearson 2485 SS |
#7 | |
Hey Mike, when you say "squirrels" are you taking about Jay? . .
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
The patch sounds like the way to go! I was thinking about trying a fiberglass patch,but this sounds much easier.
Liked 3 Times in 2 Posts
Look into a great product called Eternabond. It is the best RV seam sealer tape out there.
http://www.eternabond.com You can order direct or some RV dealers carries some of the sizes. |
