Liked 43 Times in 29 Posts
I was hoping that I wouldn't have to pull the head, however that seems the concensous. I thought there may be a way to inject throught the intake some sort of liquid to breakup the carbon, like GM Top Engine Cleaner.
Mark Ruset 2048 STK |
Mark I had the same thing with my previous MH...tried a few different spays, gas treatments...didnt work...Had to pull the generator out and pull the heads off...PIA for sure...also I dunno if you can do it in the MH, it was easier for me just to pull it out....
Dave Steltz 135G SG/SP/SST BIAECH Racing Team |
Liked 41 Times in 13 Posts
Mark, You might try some sea foam from napa. Start gen, and pour it into carb and stall out the gen. Alloy to set for between 20 and 30 minutes then restart. It will smoke alot but may loosen up and clean out your carbon deposits.
Brett McFarland A/S |
Mark ,I,ve used the GM upper cyl lube for many years ,worked for us. Sprayed it in an let it set , i used a long flexable hose to get in further.
Spin it over spray, let it set, repeat .I always had the headgaskets but never did pull the heads .Running generater with no load on it seems to be the enimey..... |
Thanks to all who replied, I'm going to try the GM Top Engine Cleaner. I let you all know how it went
I had the same problem. I thought is was a bad rod bearing or broken piston. When I took the heads off I found a smashed chunk of carbon on top of one of the pistons. I probably could have sprayed something through the spark plug hole to dissolve it but I already had the generator out and apart. I would try some carbon cleaner before taking it apart. You can try a marine dealer who sells outboard engines. They carry several different types of carbon cleaners you spray into the engine while running.
4878 SS/GA 66CHEVY II |
Thanks Darrin
I'm feeling alot more confident that carbon is my culprit especially since the generator has not seen any real use in the past 3 years. I"m going to try a spray through the carb first on a hot engine and if that fails I'll try going through the spark plug hole and fill the cylinders up with a cleaner and trying to dissolve the carbon
Liked 544 Times in 213 Posts
The Onan brand, 4 C cleaner is a good product but it will never clean the carbon as well as I do when I do one of these machines. Removing the heads is the only way to really get the job done properly. It is a recommended service by Onan every 500 hours. Doesn't have to be done that often but will need that service at some point in it's life.
The carbon buildup is very bad on these units and especially on the rear cylinder. Removing the heads.....clean them to like new and I also do the pistons and the valves and seats. The backs of the intake valves will have heavy carbon deposits. They can get so bad the engine will not turn over! Every time you shut it down the remaining fuel solidifys and builds up on one side of the piston due to it being a horizontal engine......The carbon piles up so high it will stop the engine from turning over and that is also the carbon knock you hear. We ( me and Matt Schurman) removed one of these units from a Salvation Army canteen vehicle at the World Trade Center site just after 9/11......and that one was the first time I saw one so bad it would not turn over.....I fixed it up and it ran for years after that....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 01-05-2012 at 05:49 PM. |
