#21 |
Liked 11 Times in 5 Posts
I am working on a 67' Chevy II post car. Its a tribute car to "Grumpy Jenkins ". It should be done sometime around mid 2012, or earlier if things go well. Its in the body shop now. I have lots of parts here and it will be at Wisecarver's soon for a round tube back-half,4 link and cage. I used to work there and I will get to help do a lot of it hopefully. The combo will be a 275 HP 327 and I will run SS / F . It should be a neat deal.
#22 |
wisecarver has mine now should be done in a couple of weeks 327 66 chevy 2 he did it all should look nice.
#23 | |
FIREBIRD 1998Cont350350350350350350B*C*D**B*C*D**285hp285hp285hp285hp285hp285hpFIREBIRD101Coupe 2 DrConvertible 2 DrFORMULA101Coupe 2 Dr9.559.8711.85Convertible 2 DrTRANSAM101Coupe 2 DrConvertible 2 DrFIREHAWK101Coupe 2 Dr Firehawk8.829.1010.93S/SS Factors346 335 279 346 335 279 1.1.108.26.031.1.108.26.03WS6WS6WS6RAMRAMRAMAIRAIRAIR 1LE 1LE 1LE OPTION OPTION OPTION |
#24 |
Maybe they fixed it. My '98 WS6 TA convert daily driver is certainly an LS1.
Ed Wright 4156 SS/JA |
#25 | |
Liked 534 Times in 143 Posts
The stuff you copied above is LT1 info. |
#26 |
Saw that 346 and was thinking cubic inches.
#27 |
Early 98 was LT1 cars.. Late 98 was LS1 cars. The option code label is still in the car. It def says LS1 option on the label. Kyle, do you have a LT1 engine that you would like to sell ? Uhh CHEAP.
#28 | |
I am confident your car is a LS1 since it is a 1998. The NHRA guide for whatever reason only lists the LT1 for the entire year. 1998 is LT1 only. There is some controversy about that, but it is what it is and there isn't a performance advantage of the 1998 over the 1997 in the LT1 config. I do have my spare LT1 that is fast, very fast. I would make you a good deal if you are truly interested. Kyle |
#29 |
I was working on those when the '98 production began. None were LT1s. No matter, a '98 body won't run one bit faster than a '97.
Kyle's engines are fast.
#30 |
Thanks Ed, but let's give credit where credit is due. Pete, Jeff Warren, and even you had a hand in all of that.
I may have cost my engines a full tenth with my fiddling. Just think what they would do without me massaging them. ![]() |
