Old 12-22-2011, 02:27 AM   #31
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Re: Roadsters in TS or TD
Within a few years, the street roadsters in comp will be knocking on the 7.40's so a cert will have to be developed sooner or later. They are going 7.60's now and will probably go 7.50's in mineshaft air.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 12-22-2011, 09:10 AM   #32
Adger Smith
Liked 880 Times in 311 Posts
NHRA will probably do like they did before and Change up the class. Back in the 90's they did away with the 5.5 lb per cu in "A" class and moved "B" up to "A". They could downsize the cu in of the class. They might even add weight. You can bet they will slow them down rather than re cert them. The areo on any Comp Legal Street roadster has no business going that quick.
Adger Smith (Former SS)
Old 12-22-2011, 02:34 PM   #33
TS310C
Originally Posted by Adger Smith View Post
As Jeff said the usual left steer roadster had a frame that was a system of hoops with the cage sitting on top. Since they were off center it appears that in crashes they were getting twisted off, along with the driver's head and upper body. Even the well built left steer roadsters, Cage hoop running all the way to the lower frame rails, is required to put in the little gussets. There is daylight and dark difference in the center steer alterteds and left steer roadsters. The new Vette bodies are way more aero and the old 27's are like a wing flying upside down. Bad areo. They have no place in TS if you ask me. That is just an accident waiting to kill someone. Yes, I feel I can speak as an authority on left steer roadster. I'm a left steer roadster owner and a survivor of another one that crash @ 154 mph. (Vinny's Comp World champ car)
Just so I understand what you are saying here... You think that a full bodied car is safer than a left hand steer roadster? If that is in fact what you are saying, you never saw some of the cars that used to run T/S in div 3. LOL
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
Old 12-22-2011, 03:33 PM   #34
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
I had mentioned in an earlier post that I don't think that the roadsters will certify any faster than a 7.50. I think that is why they won't let them in. They wont let a door car in unless is has a 6.0 tag on it, even if it will only run 7.90's. NHRA is not going to start trying to police which car has what cert and making sure its not running faster than it is certified for, so the easiest way to do that is not let a 7.50 cert in the class. At least thats my 2 cents worth. lol
Chuck
C and W Racing is offline   Reply With Quote
Old 12-27-2011, 10:38 AM   #35
Bill Baer
Ryan
Obviously a roadster like yours would have a couple of advantages in top sportsman it 's lighter and has much better visibility to drive the finish line.
So if they allowed cars like yours in, it would soon make door cars obsolete.
As far as top dragster it think there could be a safety concern with short wheel base roadsters running in the 200+MPH range (It may not have happened yet, but if allowed it surely would)
So I don't forsee these thing changing in near the future.
Old 12-27-2011, 12:41 PM   #36
TS310C
Originally Posted by Bill Baer View Post
Ryan
Bill, I see what you are saying but.... The top sportsman fields have been faster than the top dragster fields several times. My point is that the shorter wheelbase top sportsman cars are often faster than most of the top dragster cars (not all of them, but several). They also are allowed to run altereds in top dragster and they have short wheelbases too. Some of them are pretty out of control.
Ryan Koener
S/G 310C
Old 12-27-2011, 01:22 PM   #37
C and W Racing
Chuck
Ryan, what will your roadster certify to? If you know the answer, then you know the reason
Chuck
Old 12-27-2011, 01:25 PM   #38
TS310C
Chuck
My car is plenty safe to go high 7's (which is all the faster it will go). Not saying I could qualify at every race, but I could at some.
Ryan Koener
S/G 310C
Old 12-27-2011, 01:33 PM   #39
C and W Racing
Ryan, I don't doubt that your car is plenty safe. Like I keep trying to say though is, a top sportsman car has to cert to 6.0. NHRA will not let a 7.50 car run top sportsman. Roadsters wont certify to that, so they are not going to let one in the class. Don't shoot the messenger
Chuck
Old 12-27-2011, 01:58 PM   #40
TS310C
Chuck
Thats actually not true according to the rule book. You only have to be certified for as fast as you are running.
Ryan Koener
S/G 310C
